  • Accurate Radon
  • Accurate Pumps
  • Contact
Toll-Free (800) 404 - 0488
info@accurateradon.com
Accurate Radeon Accurate Radeon Accurate Radeon Accurate Radeon
An exceptional provider
of radon removal in DuPage County!
  • Accurate Radon
  • Accurate Pumps
  • Contact
About
Home About
Welcome to Accurate Radon – An exceptional provider of radon removal in DuPage County!
Our company’s approach is unique. We understand the interrelated nature of the soil gasses and water under and around your home. They share the same pathways and changing one can significantly impact the other. Our expertise in Radon Mitigation,Water Proofing, Sump Pump and Backup Pump Systems makes us uniquely qualified to provide comprehensive, long-term solutions that other service companies simply can’t. Our clients don’t need to try to manage and coordinate 2 or 3 separate service firms that can miss or ignore serious interrelated problem areas.
  • We consider our client satisfaction to be our greatest asset.
  • We are a dedicated and successful local small business, committed to providing 100% total client satisfaction, since 1994.
  • We offer quality workmanship and materials installed by Illinois state licensed technicians and skilled craftsman, on every project. We also ensure proper system engineering focused on providing low energy usage and the lowest possible Radon levels.
  • We have the lowest documented post mitigation radon levels in Illinois over 2006, ‘07, ‘08 with 82.5% at 1.0pCi/l or less and 97% at 2.0pCi/l or less.
Accurate Safety Solutions removes and recycles all used, discarded or replaced materials & equipment.
We Provide Preventative Maintenance and follow up Radon Testing Programs, with Lifetime Warranties. Dedicated to provide accurate, quality service and to exceed your expectations.
The dangers of Radon lurk just around the corner. Like a viper in the night, this natural agent lingers in empty rooms and corridors. It can even run in complex piping systems. If you think that you need Radon mitigation for your home or office Accurate Radon can help you out. Ever since 2002, the company has been servicing clients all over DuPage County and other nearby areas. Many clients were amazed by the company’s extensive knowledge of Radon-based procedures, as well as its high-standard customer service. Since Accurate Radon has already dealt with many service requests, the company developed top-notch operational strategies. The Accurate Radon Team is also well-trained in handling emergencies, assessments, and routine maintenance procedures.
Aside from Radon mitigation, Accurate Radon can also handle waterproofing service, sump pump, and backup pump installation. All of these services are offered as a package, thus giving multiple options for all clients. Through this method, you no longer need to contact separate firms to avail such services. Accurate Radon can make everything convenient for you. We also ensure that only the best materials and components are used for any project. This ensures the integrity and quality of our services. We also recycle materials so that they won’t be wasted; this clearly emphasizes our green methods.
Utilizing Accurate Radon’s services is a responsible move that can benefit your home or office for the years to come. Contact us today and we’ll give you a full rundown of what we can offer! can offer!
Contact Us
We're currently offline. Send us an email and we'll get back to you, asap.
Send Message
Contact Us
  • Accurate Radeon
  • Will County Illinois and Dupage County Illinois
  • (630) 876 - 0800
  • (630) 562 -2343
  • info@accurateradon.com
Hours of Operation
Mon – Fri 8 to 6
We work Most Saturday 9 – 12
© 2025 · Accurate Radeon .
  • Accurate Radon
  • Accurate Pumps
  • Contact
